주요 콘텐츠로 건너뛰기
The GeForce GT 1030 was an entry-level graphics card by NVIDIA, launched on May 17th, 2017. Built on the 14 nm process, and based on the GP108 graphics processor, in its GP108-300-A1 variant, the card supports DirectX 12.
Display not output by graphic card
I plug my graphic card in slot when I plug display output cable ( hdmi ) but I screen the no device connected shows even I change my cable also
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Do you have a second monitor or system to verify if the display is working or even try a second system to make sure the video slot is not damaged. If the card is still not sending a video signal then you've isolated the issue to the card and will need to dig into the cards logic, that will require component level diagnostics.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Apurva 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 28
전체 시간: 126
