주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
10+ Year Old Battery from ifixit Canada?
I just received a new battery for my 2015 Macbook Pro, did the first charge + 2 hours and now running it down for the first time. Install coconutbattery and it says it's 10+ years old. Install a new instance of the battery, same thing. Everything else is good but a decade old battery surely isn't good news.
I spent 2x more vs Amazon because I wanted to get away from old batteries. Is this a regular thing with ifixit now?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
There are some files that may need to be manually removed so the new batteries data is recached!
Open Finder window and click on your systems drive or just used the Go > Computer menu option, navigate to Library/Preferences & locate 3 or 4 files within com.apple.power group and delete them and empty the trash as well. Restart the system. Let the system be for a good 2 minutes as it does take a bit of time for the system to rebuild the files. Once done you should see different values.
Best to do a snapshot with what you see now and then after the reset to compare.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
TJR 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 30
