주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung은 2023년 2월 1일 “Unpacked/언팩트” 행사에서 Galaxy S23 라인업을 발표했습니다. 새로운 Galaxy Book3 및 Galaxy Book3 Pro 시리즈 노트북도 발표되었습니다.
Screen not working after battery replacement
I changed the battery because it wouldn't hold a charge...Everything in install went good. I turned it on and Everything powered on, I put it to charge and it's charging good.. So i go to sleep leaving it charged. I wake up and the screen won't power on or anything. But when I do connect a charger it vibrates to indicate it's connected. I try connecting to a laptop but nothing appears but it does vibrate twice when you connect it. I re checked ribbon connections and everything is connected good...Not sure if the screen just went out....Never had a problem with the screen before this.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Same problem happened to me last saturday, but on a Samsung S20 Ultra. After replacing the battery, everything worked OK. I launched a 4k Video to speed up discharging for battery calibration then after a while, the screen started flicking, went black and would not switch on again. When I held the power button, the phone was vibrating, indicating that it was working, but the screen stayed black. I brought my phone to a repair shop that confirmed that the screen had died. It took him 30 minutes to replace it with a new one for ... 150€. Ouch ! But now the phone works perfectly with a brand new Battery and Screen.
I'm wondering if the reason why Samsung stopped selling batteries alone but bundles them with a new screen is because of this problem ? There's no logical reason why someone who wants to replace a battery would also replace the screen unless replacing the battery would under certain circumstances cause damage to the screen (planned obsolescence ? 🤫).
Anyway, I hope you'll fix your problem without having to buy a new screen. Good luck !
PS : On the other hand, I replaced an S23 Ultra Battery the same day and everything went ok (except that the battery charges slower than the original one but it's another problem).
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
miguel m 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 55
전체 시간: 497
