주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
Track pad replacement parts and tools
Hello, I managed to spider crack my track pad and would like to replace it. It has been clicking for a while but otherwise works fine after I changed the track pad cable. If I were to replace the track pad, cable, and battery what are all the parts and tools I would need? Do I need to replace the battery? - I heard I do if it comes out. If so will the full battery replacement kit have everything I need as far as tools to replace the track pad and cable as well? Or if my track pad works should I just not bother? My battery life is ok for 10 years old I think, any input is appreciated, Thanks for your time.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
1st off install CoconutBattery and see what info is displayed on the battery, your looking for it's capacity, anything under 60% suggests a fresh battery would be on the cards. Take a look inside to see if the battery has swollen in any way is also a good idea. Post that info onto your question so we can have a look also. The guide for MacBook Pro 13" Retina Display Early 2015 트랙패드 교체 will tell you all the tools you will need to change the parts mentioned & depending on how successful the battery removal was decides on getting a new battery, I have removed them and installed them back before many times without issue, just take it easy.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Snewcomer6 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 7
전체 시간: 79
