주요 콘텐츠로 건너뛰기
New Nintendo 3DS XL로 알려진 Nintendo 3DS XL 2015년형은 2014.10.11에 일본에 출시되었으며 북미에서는 2015.2.13에 출시되었습니다. 대한민국에는 2015.5.1에 출시되었습니다.
3DS not charging properly
Hi, this device will not charge properly, when plugged in with a brand new battery, the device will show the orange charging indicator, after unplugging the charger the orange charging indicator stays on. The device will NOT turn on. I have already tried 2 different chargers, the battery is brand new.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi!
Did you had the same with original battery? If not, it could be that the replacement battery is faulty.
I would try a new one first and see how that goes.
If the same issue is happening again, then you might want to check the motherboard.. Also please check the fuses which are labeled with "F" on the motherboard with a multimeter.
If you have any questions, please let me know!
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Hey, the problem seems to have worsened now, I haven’t checked it with a multimeter yet cuz i didn’t but it yet, but when plugged in, the orange charging light shows up for 5 seconds then goes away. I’ve tried two different chargers and two batteries, any help would be appreciated.
Okay, when you tried multiple batteries and the same issue ocur, it's motherboard related. I would check the fuses first. How are the battery pins?
Thanks!
댓글 달기
답변을 추가하세요
JoeGaming 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 57
