주요 콘텐츠로 건너뛰기
2020년 5월에 HP에서 출시한 Intel 비즈니스 노트북인 HP EliteBook 840 G7의 수리 안내서, 분해 및 문제 해결 정보입니다.
Wifi button is bot showing up in control center..
I don't have internet on my laptop, the wifi button just disappeared on control center
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
This could mean a couple things, but usually the WiFi being gone altogether is indicative of a hardware failure. Or the WiFi service is disabled.
Assuming you're running Windows, I would right click on your Start menu and select Device Manager in. the list. Within that you should be able to see if there are any issues with any Network devices. If there is an error it will usually be obvious when you open the menu.
Check and see if your WiFi card is even present in the network devices. it would usually be listed specifically mentioning WiFi or mention specific wifi standards (n, ac, or other).
If it's not present, likely you'll need a new Wifi card. You can replace the internal one, but they make lots of USB WiFi adapters as well.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Lava Lava 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 44
