주요 콘텐츠로 건너뛰기
May 2019 mfg date Model no.XL2540-B 244hz 1ms Gaming monitor
Double image on Zowie 240Hz
Hi im having a double image problem on my zowie monitor, ive tried changing the cables and its not from the gpu other monitors work fine even w the same cables used on the zowie, cant send it to warranty cause it was from a freind and its already past it as well, the only videos i can find of fixes are from people cutting out the connections on the monitors pcb, would like to know if anyone has had thsis problem before if they had found a solution that doesnt require blocking the conections on the pcb.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hello man i have the same issue with mine
https://www.reddit.com/r/Zowie/comments/...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Manuel Nunes 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 10
전체 시간: 98
