주요 콘텐츠로 건너뛰기
Nintendo Switch/닌텐도 스위치는 도킹 스테이션을 통해 TV에서 플레이하거나 이동 중에도 플레이할 수 있는 휴대용 게임 콘솔입니다. 2017년 3월 3일 출시되었습니다.
New Battery arrived with 100% Charge
Hi, I just bought a new battery from iFixit, and successfully replaced it on my switch. However, when I powered it on, I noticed it was at 100% charge, from what I've heard it should usually only have a nominal charge. When I booted into hekate after putting the new battery in, the stated capacity was 3701 mAh out of the designed capacity of 4310 mAh.
I did let it drop to 0% and fully charge it to initiate the calibration, but according to Hekate's battery info on my switch, that dropped the battery capacity by 3%, to 82% (3505 mAh) of the original capacity. I'm not sure if this battery is new, or if I should finish calibrating it to see what it reports.
Not as important as my question but I am unable to get my switch back open without breaking the back plate, as the head of the screw that goes into the right joy-con rail broke off, so I may not be able to check the battery again without damaging my switch.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi!
Could be the battery or the charge IC.
I would first use it for some time and try to calibrate it a few times and see how it goes. Otherwise, return the battery and get yourself a new one.
In the worst case, the charge IC need to be replaced (this do requires soldering).
Please let us know how it goes!
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Alexander 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 19
전체 시간: 96
