주요 콘텐츠로 건너뛰기
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 질문 전체 보기
My iPod Touch volume/power cable broke.
Now my iPod touch won't show anything. I know it's on because when I hold the home button the voice assistant talks. I did see a white screen once. Also my computer detects it. I can't do any reset because my flex cable for the volume/power is ripped. But i'm also not sure a hard reset would work. Did this happen to anyone similar? Did you fix it? How?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Hate to say this, Justin, but when you replaced the lcd and pulled up the logic board you probably ripped the power/volume flex cable. To repair your iPod, is going to involve desoldering the hot terminal off the battery, pulling the logic board, and soldering in a new flex cable. And if you don't have the right equipment and experience you'll dig yourself deeper into a hole that can include lifting solder pads, solder splash, tearing other cables etc. At this point I suggest you send your iPod off to a business that specializes in iPod repairs.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It sounds like the front panel display went out. I would try replacing it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I'm having exactly the same problem. How did you fix it?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Justin Narvaez 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 1,081
