주요 콘텐츠로 건너뛰기
2021년 10월에 출시된 Google Pixel 6 스마트폰의 수리 및 분해 정보입니다. 모델 번호 GB7N6 및 G9S9B16으로 식별됩니다.
Dropped phone doesn't turn on unless connected to USB
Hello,
Just dropped my phone on the floor, it went black and wasn't turning on. After I connected it to USB, Google logo appeared on the screen, blinked 3 times and it booted normally. The second I disconnect USB, it goes black and unresponsive again.
I assume there's no power output from the battery?
When the phone is on (with USB), I can see the battery charge and charging icon, so it's not completely disconnected.
1. Should I try to check the battery connection?
2. If connection looks good, does it make sense to try to replace the battery?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @jackjones43148
Best option is to open the phone and check if the battery flex cable is just loose/disconnected or if there's some other obvious damage.
Here's the ifixit Google Pixel 6 repair guide that will help.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
thank you!
(comment too short)
댓글 달기
답변을 추가하세요
jack jones 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 45
