주요 콘텐츠로 건너뛰기
Portable cassette player from 1996.
When I insert tape into walikman, the tape gets pinched
When I insert the cassette into the walkman, after a few seconds, the tape gets pinched into the roller. How to solve this problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Clean the rollers to prevent tape from being "eaten":
Use high-concentration isopropyl alcohol, 99%, if you can find it and a Q-tip (cotton swab) to clean the pinch rollers and capstan, remove any Iron oxide residue 'til your swab no longer gets soiled. This keeps the tape path clean and improves the grip and lessens the chance of damage to your tapes.​
So:
1. Power off and remove your tape.​
2. moisten a good quality cotton swab (less fiber shedding) in isopropyl alcohol. Don't use rubbing alcohol, as it usually has scents and oils.​
3. Gently clean the pinch roller and capstan (The white plastic roller and the thin metal one) with the swab while turning the roller to get to all of the surfaces.​
4. Repeat using a dry swab to remove excess moisture.
5. Repeat steps 3 & 4 until no more brown or black oxide residue comes off.​​
When you've done that, set it aside to dry completely before using it again.​
To prevent future problems repeat this every few months, it should also make your music sound better!​
If the rollers shed black residue, they may need replacement.​
Good Luck!​
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Arvind Karle 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 29
