주요 콘텐츠로 건너뛰기
Repair and disassembly information for the Nokia G42 5G Android smartphone, first released in June 2023, built by HMD Global. Identified by model numbers TA-1581 or TA-1591.
Hangs at Nokia logo, will not start
After restarting to do a system update, the phone has got stuck in a boot loop. I'm wondering if there's any possible way to resolve it without forcing a factory reset/data wipe.
Essentially, every time it restarts or powers on, it makes it to the Nokia logo screen and then hangs indefinitely. I can use the power + volume down button to enter the fastboot screen, but the options given are not helpful - all I can choose from is:
Start
Recovery Mode
Power Off
Restart bootloader
All of these options result in the logo hang, even the recovery mode option. I see another user had a similar problem but says the phone eventually recovered itself on its own. I'm not really eager to wait around to see if mine will do the same - is there any hope of a quick fix or am I just going to have to factory reset?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi.
I had the same problem when replacing the screen. Hold power button to turn off then volume down and power to go into recovery mode and use power button to select it then choose to restart it. After that it might still show up the logo stuck again which it did for me but I hold the the power button down and turn it on again and it worked.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Lisette 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 11
지난 30일: 17
전체 시간: 17
