주요 콘텐츠로 건너뛰기
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 또는 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz 또는 Core i7 2.8 GHz) ID iMac11,1
질문 마감됨
Install Air SSD in iMac AirPort Card slot?
I'm about to acquire a 128GB SSD from a 2010 MacBook Air, and have discovered that it is indeed not mPCIe but rather a slightly different connector. Is this the same connector used in the AirPort card? I'm going to attempt intalling this SSD in my iMac's AirPort card slot unless Mayer says it won't work, because he might have tried this already ;)
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I don't know if a MacBook Air SSD has ever been put in an AirPort Extreme slot. I am not sure if the connectors for each one are physically the same. (actually based on photos the airport extreme has more contacts and is slightly wider). I have seen someone successfully install a hard drive in an AirPort extreme slot using Mini PCIe
http://www.xlr8yourmac.com/systems/mini_...
but I do not think you could fit the SSD in as it is rather long and if you did I don't think it would work.
Hope this Helps
(I guess we will wait for mayer)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 1,199
