주요 콘텐츠로 건너뛰기
No Display after switching to Ultimate with Armory Crate
Hi all, I was Switching SSD and I mistakenly switched to Ultimate in Armoury crate before nvidia drivers was fully installed, now laptop turns on window log in sound can be heard but I get no display, not even from the HDMI i guess it's stuck on display from Nvidia only but drivers are not present.
I have tried using narator to switch back but couldn't find the graphic settings anymore, tried booting from a fully functioning SSD of the same laptop with all the drivers present, still nothing.
I am thinking of removing the BIOS chip and resetting it with CH341a progrmmer. Do you guys think it will work or it's a waste of time?
NB. I've also tried to restore bios to default through f9 and f10 keys, nothing works. The screen wont display anything either from screen or HDMI
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
This sounds like the iGPU/dGPU mux got stuck in dGPU-only mode before drivers were installed, which can completely kill display output. Resetting BIOS with a programmer is usually unnecessary and risky. Before that, try pulling the CMOS battery, disconnect main battery, hold power 30 seconds, then reboot. Also try blind-booting into BIOS using F2/Del, or plugging in an external monitor after Windows loads. If none of that brings the iGPU back, a full EC/BIOS reset via service center is safer than flashing the chip yourself.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ovieroghene 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 14
전체 시간: 14
