Capital oven/range model PSGR366: back range igniters rarely spark
Update: corrected the igniter module part number below.
The 3 back burner igniters on my Capital oven and range model PSGR366 spark only rarely. I can light them manually with a lighter and they work just fine. I have cleaned the burner caps and igniter tips. If I tilt the burner caps so they are closer to the igniter tips, they will spark consistently, but the spark is weak. The back igniters have longer wires leading from the igniter module than the front igniters as the igniter module is located at the front of the range. The 3 front burners work just fine. I also switched the igniter wires for the two left burners at the igniter module, and saw the same behavior: front igniter sparked, the back igniter did not. I noticed that when I plug the oven back into the outlet, I sometimes here a single spark. This does not happen every time I plug it back in.
The behavior is consistent regardless of which burner knob I use to trigger the igniters (all igniters are triggered by any of the burner knobs), so I don’t think this would be caused by poor contact in the burner knob switches. Plus the igniter module has separate power going to it, so I don’t think the power for the sparks goes through the knob switches, but that's just a guess.
My theory is that the igniter module (Tytronics model RI 120L-6 PA02 0042, see image) is outputting a weak pulse such that the back igniters with their longer wires aren’t getting enough voltage/current to spark consistently. However, the wires aren’t that much longer. Maybe a foot. A replacement is a bit pricey, so does anyone have any thoughts on what else it might be or what other things I could try? I have a digital multimeter. Can I diagnose the igniter module?
좋은 질문입니까?
