주요 콘텐츠로 건너뛰기
2.2, 2.4, 2.5, 또는 2.6 GHz Core 2 Duo 프로세서
759 질문 전체 보기
How do I test my LED Driver Board(s)?
Hello everyone, my A1226 MacBook Pro is having a problem with the backlight not working. Otherwise everything seems to be functioning normally.
So far I've replaced the LCD screen, the display data cable, the LED Driver Board and the iSight cable (know this last one is most likely unrelated).
After replacing all of these things, the problem still remains.
I know that this points to the logic board being faulty as the most likely culprit.
Before I blame the Logic Board, I was wondering if anyone might be able to tell me how I can test my two LED Driver Boards to see if they are faulty.
I only ask this because I purchased my replacement LED Driver Board from ebay at a ridiculously cheap price - they said it was working properly, but I bought it for just $9 (sells on ifixit for $60). Hence my suspicion that my original LED Driver Board failed, and that the cheap replacement I bought might also be faulty.
Do any of you know a way that I can test my LED Driver Boards, armed with my multimeter and various other household items?
Otherwise, if you know of a way that I can test my logic board to be sure that it is causing the problem, I'd be very happy to hear it as well!
Bottom line, I'd like to know which component is causing the problem, and would like to figure this out using another method than trial and error.
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
선택된 답변
Hook your machine up to an external monitor. If you get a picture, you've isolated the issue to past the GPU.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
I do get a picture when it is hooked up to an external monitor. In addition, the LCD is displaying a picture just fine - it is just that the backlight is not working. If I hold the screen in bright sunlight, or hold a flashlight to the LCD, I can see that it is working as it should.
Sounds like you got what you paid for on eBay with the inverter board. Either of these part numbers should work for you, 922-8143, 922-8354.
댓글 달기
When my backlight went out, and everything was still great on an external, I ended up replacing the left I/O Board, and got my backlight back :]
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi
Actually you need to see the full spectrum of LED driver.
We have made a website specifically for this
It is www.leddrivertesting.com
Jeff: Please visit the website. I am waiting for your recommendations.
Thanks
Ajay Gupta
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jeff 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 2,031
