주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
Caller name not showing ...
i m using a iphone 4S from sprint. i m using a Gevey card. this phone is not showing any caller name during incoming call or msgs. if i add a contact with +91 then it shows name during incoming but after this i can't reply any msg to that no(like +9198763*****). i can send msg only to without prefix country code.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 4개
선택된 해법
i updated the Ios of the iphone to latest firmware 5.1.1 then i changed the Gevey card and program it to new settings acc to their carrier of the phone . This solved the problem of messages and caller name display. i have to do is to save all the number with country prefix . thnx for help
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
Service providers in the USA charge extra for caller ID sometimes. If your plan is new, the provider may not be providing caller ID. Call and ask them. Also check this on the use of +91: http://countrycode.org/india
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
my problem is that phone not showing name of the contact . it just show the number if i add the +91 with all the contacts then it shows the contact name during incoming . after adding +91 i cannot reply msg or send a new msg to that number . i have to remove the +91 before sending the msg to any number.
If your customer is calling from a cell phone, most of the time, in my experience, the name will not show up unless you've programed your phone to show it. Ask if they're using a land line or a cell phone.
in india if any calling from any line means cell phone or landline or you have saved that number in your phone's address book then your phone display only name not the number even you have saved with country prefix number or not
댓글 달기
guys have got a sure shot solution for contacts and text message issues for iphone users. please visit the below mentioned link and pls do leave a feedback if it helps u.
http://foneadvisor.blogspot.in/
이 답변이 도움이 되었나요?
점수 0
댓글 달기
my iphone does not show caller's identity anymore. Used to before.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
SIMRAN 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 29,580
