No audio at headphones jack
I have two iPod 5g 30 gig with no audio at headphone jack. replaced jack on both units, and still no audio. all other functions seem to be working properly. thanks, D.C.
좋은 질문 입니까?
좋은 질문 입니까?
Hi,
try if there is sound via dock connector, if not the logic board seems to be damaged. Before buying a new logic board, check the volume preset in the settings of the iPod.
해당 답변은 도움이 되었습니까?
I checked one unit and it has perfect audio at dock connector. also checked volume limit, it is at about 3/4. what does this mean? thanks
How did you checked the dock connector? Did you use a usb cable connected to a pc/mac, or a dock cable connected to an audio system? If you used a dock cable, it means that there seems to be something wrong with the headphone jack/hold switch. Does the hold switch work normal? Maybe the cable of the headphone/hold switch isn't seated properly in the connector on the logic board.
해당 답변은 도움이 되었습니까?
I did use dock cable to audio system . hold switch works fine, no headphone sound ? frustrated!
At first you should try again with another headphone. Last chance would be to take the headphone/hold switch from a definitely working iPod and try again. If there is again no sound, than there seems to be a completely new issue with the logic board for me.
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,362
