주요 콘텐츠로 건너뛰기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
1169 질문 전체 보기
iPhone charging only while the sim is not inserted
my iphone dropped, worked fine for tow days,
now it keep discharging while connected to charger and turned on, but charging very slowly while turned off,
then i tried to remove the sim an now it works very good with the sim removed charge is lasting for a normal time,
i disconnect it, insert the sim and the charge is drained very fast weak signal and heated. please advice,,, thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Solution is in the last paragraph, cool showing off of my knowledge below!
The iPhone has a small arm underneath the sim card tray which tells the iPhone if it has a SIM card inserted or not, when a SIM card is present, it separates the two metal contacts and so, because there isn't a current flowing the iPhone knows that there is one, and to start powering up and reading the SIM card.
There might, by the sounds of it, be a loose part which is short-circuiting the iPhone, usually from the high voltage line to naught voltage line, that would mean your short-circuiting your house! If you live in Britian you will (by law) have a GFCI (Ground-Fault Circuit Interrupter) If voltage is coming from the live to ground (or zero) then it shuts off the power supply, to stop you from getting electrocuted! In the UK they are annoyingly very sensitive.
As your iPhone is still getting charged a little that means it is passively charging the Lithium battery, which isn't good for the battery life! The iPhone has a miniaturised and adapted GFCI inside of it which will be limiting the amount of voltage the iPhone takes in. In other products it usually warns you and tells you, the iPhone doesn't. Apparently it would confuse people to say 'YOU MAY GET ELECTROCUTED or YOUR iPHONE WILL SOON EXPLODE!'
Don't worry it's not as serious as that, but, as you may have already guessed, you'll need to replace the module were the sim card tray goes. That would be your best bet.
Hope this helps!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
thanks a lot, this is very informative, appreciate your time.
댓글 달기
귀하의 답변을 추가하세요
wessam 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 39
전체 시간: 8,304
