주요 콘텐츠로 건너뛰기
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 질문 전체 보기
질문 마감됨
I Replaced screen(workd perfect) I opened again and screen went white
Hi, i replaced my ipods broken screen and it worked perfect but then i found that wifi isnt working so when i replaced the wifi antenna i broke the wire(ribbonn) on left side almost half way down and when i put it all together the screen was white (the same screen workd perfectly before) i think it maybe the ribbon i broke? i could really use some help
I tried the home, volume, and power button thing didnt work
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
A hard reset should sort this out! It is a very common problem with iPod Touch 4th Generation screen replacements, hold the sleep and home button until it turns off and then power on normally.
That really should do it.
Hope this helps!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 257
