주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2397 질문 전체 보기
CHANGING PARTS IN MY iPhone 4, Water Damage
OK so i have an iphone 4. 8 gig (2 weeks old) from rogers, in Canada.
My g/f dropped it in the toilet and it has water damage, it turns on for a second and says connect to iTunes.
So i did lots of research, took the phone completely apart, dry'd it out in rice for a couple days, put it all back together and turned it on, it started no problem, and even made a phone call!! i was so happy. the problem is the battery is bad because of the water and the phone heats up really bad. I'm pretty sure i need a new logic board and battery.
My question is:
1. Do i need a new logic/motherboard?
2. Can i use a 4s logic board/motherboard?
3. Can i turn my iphone 4 into a 4s by swapping necessary components? (camera, motherboard?)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
First and foremost, I can glean from your question that your unit is an iPhone 4, and not an iPhone 4S. However, you should give us the last four letters and numbers of the serial code.
1. No one can tell that for sure. The only way to know is changing the battery, booting up the unit and tell how it goes. You may also want to clean it more throughly with isopropylic alchol.
2. Not that I know. If you go through the iFixit site, you may see that several key parts of the iPhone 4, including the bezel mount and some of the assembly, are radically different, thus...
3. ... you can't "upgrade" your unit.
You could, however, if your current issues are "just" a really short battery life and your unit heating try to fix it by buying a new battery only, and ordering a new logic board only of other troubles arise.
It's a safe bet saying that the plunge in water shorted up the battery, and will account for a short battery life and the heating up device (the logic keeps trying to charge a broken down battery).
The rest... has to assessed later, or in a professional lab.
If you're handy enough to do it by yourself, the safest course of action is:
  1. Acquiring some isoprophylic alchol
  2. Dismantling your unit, cleaning up gently the logic board and pay attention to suspicious patches of rust and other water debris, scrubbing them really gently
  3. Let the alchol dry: it dries much faster than water, that's why it has to be used
  4. Replace the battery
  5. Close the device, reassess the damages
  6. Eventually, report here how your iPhone is holding up
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Can i replace a iphone 4s mother board with an iphone 4?
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
No. iPhone 4 and 4S are not compatible.
Okay so if i change my mother board to a new mother board would it be a new set up of icloud??because my old icloud is lock i cant download anything
댓글 달기
귀하의 답변을 추가하세요
Jordan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 9
전체 시간: 6,728
