주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fixing my LCD Screen
Dropped my HP 14 ep-2000 on the floor. Small patch of dead pixels in the top left corner of the LCD screen and horizontal and vertical lines across the screen. Lines flash on and off. I have two questions. What screen do I need to order and how do I repair it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
The dead-pixel patch and flashing lines after a drop strongly suggest a damaged LCD panel. Don't order a screen based on “14-ep-2000” alone; press Fn + Esc to find your exact HP product number, since panel options can vary. For the repair, follow the HP service guide, disconnect the charger and internal battery, then carefully remove the bezel and panel.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Thanks for the tips Malcom! My laptop's bezel does not have any visible screws to remove it. How would I get the bezel off safely?
의 공유
@eriksonc The bezel is usually held by plastic clips, sometimes with adhesive. On the HP 14-ep0000/ep2000, HP has an official teardown video showing bezel removal at 26:16. Use a plastic spudger and work slowly around the edges; don't force it, or the clips may break. Make sure the laptop is unplugged and the internal battery disconnected first.
I found this vid online. https://www.youtube.com/watch?v=dJiJCivm...
의 공유
댓글 달기
답변을 추가하세요
Erikson C 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 45
전체 시간: 65
