Screen/Computer Freezes when Pressure is put near Battery connector
Hi All,
If I pick up my computer on the bottom left corner with the screen open, the screen freezes and either turns completely gray, or turns mixed colors like when a magnet gets near a computer screen. Flickering with lots of different colors. Is the battery shot? Logic board shot?
좋은 질문입니까?
댓글 21개
HI,
I have got the same problem with my mac book pro. Screen freezes or turns one colour when I put pressure on the bottom area of the mac where the Logic board is. It sometimes happens too when it heats up or when it is overpowered by powerful software. Not sure which exactly. But anyway mac still heats up when powerful applications are used.
Could you please tell me what solved your problem?
Thanks
Mark 의
I have this same problem. However, I have swapped out a few batteries and the problem does not go away... As it goes away when no battery is in the computer I am at a complete loss for what is wrong...
Josh Morrison 의
I have the same problem with my MacBook pro 13, I opened it an worked with it without the bottom case and worked fine. I noticed that when I put little pressure on the logic board it flickers and freezes, so I think I need to inspect the logic board with a magnifying glass in order to find an unsoldered component that causes false contact.
Jesus Garcia, March 18, 2015
Jesus Garcia 의
Same problem on 2012 13 inch macbook pro. I think it is a bad solder joint on the ram slots. When I turn it on without the back on and press on where the ram connects to the motherboard, the screen glitches and the whole computer freezes.
ephraimkunz 의
i have the same problem , does anyone has a solotion?
eden2510 의
댓글 16개 더보기
