주요 콘텐츠로 건너뛰기
2010년 4월 출시 / 2.4, 2.53 GHz Core i5 또는 2.66, 2.8 GHz Core i7 프로세서
590 질문 전체 보기
Left fan not running but facing very small bumps
Hi,
My MBP left fan stopped working, smcfancontrol shows 000rpm, I've done a SMC and NVRAM restart, but the problem remained. Then I've opened the back cover and I was able to see only the right fan working. Finally, to confirm I've run the Hardware test and got a "4M0T/4/40000002: left side-0", which seems to confirm that this is a hardware problem.
Although, with the computer opened, I was able to observe that the fan, although not spinning, it does slightly bounces, with very small bumps, let's say a bump per second, like if it was trying to spin but it couldn't. Is it normal? Is the fan really broken? Shouldn't it be completely stopped?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
Good diagnosis
댓글 달기
답변 1개
가장 유용한 답변
No it's not normal. The fan needs to be replaced before you burn out the components attempting to make it run. Electronics won't fix them selves, or get better if you wait, only more goes wrong. Be sure to order the tools you'll need when you order the fan...every job goes easier when you use the proper tools.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
joaodrp 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 748
