주요 콘텐츠로 건너뛰기
1997년에서 1999년 사이 Apple이 제작한 베이지 G3 시리즈 중 하나입니다.
HD ata, pata, ide and ultra ata
Hi, I own a Power Mac G3 desktop beige and I've bought a new HD Western Digital 80GB WD800AAJB 7200 rpm 8MB Caviar Blue PATA. The Mac sees the HD as it complies with G3 limitations (no bigger than 120), mounts it, formats it, uses it, but just for "normal" use, I mean writing, reading files. But when I try to use it in HD recording mode, with Pro Tools, the drive seems to work, but when I play recorded files, they appear to be fitted of spikes, and I get a crackly sound, like the old dusty vinyl one. If you examine the waveform, made with a sine test, you can find many, many spikes everywhere.
Can I fix it? may be with a special drive? Or is it an insoluble problem?
The OS is 9.2
Thanks to everybody
massimiliano
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
The problem is new drives write too slow in "backwards compatible mode". This might be an option, but contact OWC to see if they have any other solutions or advice.
If this answer was helpful please remember to return an mark it Accepted.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thanks! I see the solution by OWC is not compatible with my jurassic Mac. but I'll investigate this way.
댓글 달기
답변을 추가하세요
Massimiliano Giusti 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 3
전체 시간: 555
