주요 콘텐츠로 건너뛰기
13인치 디스플레이가 장착된 MacBook Air 모델에 대한 수리 안내서, 지원 및 문제 해결 정보입니다.
3665 질문 전체 보기
missing screw post on Logic Board
Hello .
I just purchased macbook air a1237 model.
Looks like it is missing screw post and screw located between cpu's .This screw is holding heat sink as well cpu bracket (v shape ) .
Is there way to buy missing post for the screw or fix that some how ? Looks like this mac is overheating now and turns off after few min .
See pic below on link
http://forums.appleinsider.com/t/151696/...
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Try contacting iFixt directly if no one else pops up with the part.
''If this answer was helpful please remember to return an mark it Accepted..
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
i did try this road already
Then purchasing a dead (for parts only) machine from e-bay is your only hope. You might be able to negotiate with a seller for only that part-if not get the offered machine and part out the remaining good parts.
댓글 달기
If the heat sink is loose, and if a thin coat of thermal paste is missing those could be the causes of your overheating.
You could try contacting iFixit directly to see if they have the part.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Gregory Chojnacki 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 296
