주요 콘텐츠로 건너뛰기
2011년 하반기 모델, A1278 / 2.4 GHz i5 또는 2.8GHz i7 프로세서.
How to replace camera cable?
I broke the connector(camera cable), the one that is attached to the motherboard.
I ordered a new cable.
but now how do I connect it?
I need to remove only the plastic cover?
any manual or how to?
thank for answers.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
The camera cable routes up through the display assembly to the camera board above the LCD. To completely remove it you have to pull off the display glass. It's a very delicate procedure, so be careful and work slowly.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
well, but my is 2011, a you sure my case is the same?
by the way, my macbook still under in 1 year warranty, so in this case the can replace cable , or they reject to replace cable?
The unibody display assemblies have been nearly identical for 4 years. If your computer is under warranty, what were you doing to break the cable? Assuming there are no traces of you interfering with the laptop, they should honor your warranty.
댓글 달기
답변을 추가하세요
ressac 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 5,106
