주요 콘텐츠로 건너뛰기
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Replacement
필요한 것
  1. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Replacement, Battery: 1 단계, 이미지 1/3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Replacement, Battery: 1 단계, 이미지 2/3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Replacement, Battery: 1 단계, 이미지 3/3
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Replacement, RAM Shield: 2 단계, 이미지 1/2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Replacement, RAM Shield: 2 단계, 이미지 2/2
    • Remove the three identical 2mm Phillips screws from the memory door.
    • Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
  3. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Replacement, RAM: 3 단계, 이미지 1/2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Replacement, RAM: 3 단계, 이미지 2/2
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the chip directly out from its connector.
    • If there are two RAM chips installed, repeat the above procedure for the second chip.
결론
다른 222명이 해당 안내서를 완성하였습니다.
Walter Galan
694,856 평판
안내서 1,203개 작성하였습니다
댓글 한 개
Really easy to install RAM on Macbook Pro 15'' Model A1226!!
I had 2GB of RAM (1GB and 1GB), so when I read this tutorial I decided to buy one ram of 2GB 667Mhz and It is working great (now I've got a total of 3 GB). I'm willing to install up to 6 GB with this same tutorial. Recommended!
cesrafa - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 21
30일 전: 101
전체 시간: 132,894
