소개
As a car ages some of the connections can deteriorate. If your LCD display is not working properly with only some of the segments showing, or if the segments sometimes show and sometimes does not show, then it’s likely the result of a faulty connection. In some cases, the repair is relatively easy. Sometimes, the connection between the LCD and the circuit boards simply needs to be cleaned. In this case though, there is no connection that can be cleaned so the connection needs to be re-soldered. If you need more information on soldering check out the guide on iFixit.
필요한 것
Use the spudger to remove both side covers to access the radio removal holes.
다른 2명이 해당 안내서를 완성하였습니다.
첨부 문서
댓글 3개
Great guide! When I was taking mine out to swap in an aftermarket, I by accidently didn't disconnect the battery and when attempting to remove deck with the 4 C clips, I guess I shorted the backlit LED in the original. The wires of my new (old aftermarket deck) just keep messing around so I want to put this original stock one back. I was wondering if you knew or could help me find out which piece of the board or LED to replace? The LCD itself works, just not the red LED backlight when the car lights are on.
IS there any way you can help me identify this piece that I might have shorted out by pulling your deck again? I'm guessing the LED's are on the opposite side of the picture 12.
Only if you are willing. I would really appreciate any help.
Thank you
-David
