소개
Here is a straight forward bulb replacement. Only requires the simplest of tools and is a quick fix.
필요한 것
Here is a 2000 Jeep Grand Cherokee with a burned out driver side headlight bulb.
Open the hood. On top of the affected headlight assembly is a single 7mm hex bolt.
Remove the bolt
To reassemble your headlight, follow these instructions in reverse order.
다른 18명이 해당 안내서를 완성하였습니다.
댓글 11개
guide made this an ABC REPLACEMENT
Easy peasy. Thanks!
On my 2001 Jeep Grand Cherokee Limited, there was an extra screw that needed to be removed. I didn't notice it and, in trying to remove the headlight housing, broke the plastic housing that was held in place by that screw.
You didn't notice it? I wouldn't have you working on my car if you're that careless.
FixIt -
Justin answer the question we don't want to hear rude comments just the answer geeh dude so abrasive to ppl. C wats up wit that
