주요 콘텐츠로 건너뛰기
1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement
필요한 것
  1. 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Rear hatch lift supports: 1 단계, 이미지 1/3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Rear hatch lift supports: 1 단계, 이미지 2/3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Rear hatch lift supports: 1 단계, 이미지 3/3
    • Open the tail gate and either prop it up or use an assistant to hold it.
    • The tail gate is heavy and will fall if not properly supported.
    • The rear hatch has both a left and right lift support strut.
  2. 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Loosen the strut bolts: 2 단계, 이미지 1/3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Loosen the strut bolts: 2 단계, 이미지 2/3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Loosen the strut bolts: 2 단계, 이미지 3/3
    • The struts are fastened with T40 Torx head bolts.
    • Use a T40 Torx driver to loosen the bolt
    • The bolt does not remove the strut. It is pressed in to the strut and will be replaced with the new strut.
  3. 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Replace the struts: 3 단계, 이미지 1/3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Replace the struts: 3 단계, 이미지 2/3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Replace the struts: 3 단계, 이미지 3/3
    • Completely loosen the bolt securing the strut to the top of the tailgate with a T40 driver.
    • Replace the worn strut with a new one.
    • On this vehicle both struts were replaced. This will stop the tailgate from sagging.
결론
To reassemble your Jeep, follow these instructions in reverse order.
다른 8명이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
789,521 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
34 회원들
안내서 597개 작성하였습니다
댓글 4개
We just had a garage replace the tailgate lift struts on our 2002 Jeep Grand Cherokee. Now the tail is very difficult to pull closed. Is there a way to adjust the struts so that it easier to pull down closed??
Raymond Janko - 답글
Double check the work. Make sure they are mounted the right direction and that all the bolts are properly fastend. There are no adjustments
oldturkey03 -
I need to replace the lower bolt as it snapped in half. Any advice for that?
Dave Hankins - 답글
Use a drill and drill off the head. Remove the strut and use something like a pair of vise-grips and get a grip on the leftover part of the bolt. Try to remove it. If you can/ time to drill it out and retap the thread.
oldturkey03 -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 40
전체 시간: 9,995
