이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
The 4.0L 6–cylinder engine uses a one-piece coil rail containing three independent coils. Located on the right hand side (passenger side) of the engine.
The one-piece coil bolts directly to the cylinder head with 4 13mm hex bolt (M8X50). 3 of the bolts are immediately visible.
The fourth one is somewhat hidden in the back, under the coolant lines for the heater. The hoses can easily be moved out of the way.
Start removing the 13mm bolts from the coil rail. Use an extension will make it easier to clear the radiator hoses and throttle cables.
Use a smaller extension to remove the 4th bolt in the back of the rail.
All 4 bolts are identical in size and need not to be separated.
With all 4 bolts removed, the rail should easily pull off the spark plugs. One electrical connector (located at the rear end of the coil rail) is used for all three coils. It is not necessary to totally remove the rail for a spark plug change.
Rubber boots seal the secondary terminal ends of the coils to the top of all 6 spark plugs.
Use a 5/8inch spark plug socket and extension to remove the spark plug. Again, the ignition rail can be easily moved out of the way.
Continue to remove all spark plugs.
To remove the last spark plug in the rear, use a longer extension. Always ensure that the socket is properly seated on the spark plug.
With all spark plugs removed, it is clearly visible that these plugs were in definite need to be replaced.
다른 39명이 해당 안내서를 완성하였습니다.
댓글 18개
This is great, my jeep has a misfire on cylinder 4 and this helped me locate and get to the coil and spark plug, straight forward easy to follow, thank you, I will update once i'm done.
Finished replacing the plugs, my check engine light went away, misfire is gone, thank you!
well done, great post
thank you..
Very nice detailed instructions. The illustrations make it very simple to follow. The list of tools is exactly whats required. Thank you for putting the time in for such detailed instructions for a task that is very important to fuel economy as well as power/torque.
Even the plug gap and type are supplied. Thanks again.
