주요 콘텐츠로 건너뛰기
2001-2005 Honda Civic Oil level Check and oil change
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. 2001-2005 Honda Civic Oil level Check and  oil change, 2001-2005 Honda Civic Oil level Check and  oil change: 1 단계, 이미지 1/1
    • Warning: Improper maintenance or use of unapproved materials may lead to major issues with your automobile
    • Step 1: Turn off your vehicle and wait a few minutes.
    • Starting this process with a running or hot car may cause damage to both the engine as well as the person performing the maintenance
  2. 2001-2005 Honda Civic Oil level Check and  oil change: 2 단계, 이미지 1/1
    • Remove the dipstick from its' holder and wipe it down with a clean cloth
    • After cleaning, replace the dipstick and remove it again
  3. 2001-2005 Honda Civic Oil level Check and  oil change: 3 단계, 이미지 1/1
    • If an oil change is not necessary, the oil will be a dark brown, and the level will be in between the two notches on the dipstick.
    • If the level is too high or low, it's time to add/change the oil
  4. 2001-2005 Honda Civic Oil level Check and  oil change: 4 단계, 이미지 1/1
    • Step 1: After running the car to normal operating temperature, turn off the vehicle and remove the black and purple oil fill cap.
    • Underneath the car, use your ratchet socket wrench to remove the oil drain bolt and washer.
    • Remove the oil filter from the tank and allow all of the oil to drain out.
  5. 2001-2005 Honda Civic Oil level Check and  oil change: 5 단계, 이미지 1/1
    • After all of the oil is drained out, replace all parts in reverse order that they were removed.
    • If the oil filter appears old or damaged, it is wise to replace it. Oil filters can be found at any auto parts store
    • Add 5W-20 Motor oil to the level indicated in your owners manual.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Tyler Smith
회원 가입일: 10/23/13
846 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 4-5, Vijaybhaskar Fall 2013 UMass Dartmouth, Team 4-5, Vijaybhaskar Fall 2013 회원
UMASSD-VIJAYBHASKAR-F13S4G5
3 회원들
안내서 5개 작성하였습니다
댓글 2개
Where is the oil filter located? An important step was left out!!
Gil - 답글
This guide has been retired and is no longer being updated. Please use the latest version of the 2001-2005 Civic oil change guide. Thanks!
Jeff Suovanen -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 4,395
