이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Here is a view of the left tail light assembly
Open the rear hatch,( or trunk if it is a sedan). On the inside of the assembly are two retaining screws. Remove those
both screws are #6x3/4 inch
Here is a view of the assembly with the screws removed.
Insert some sort of prying tool between the tail light assembly and the body, just below the crease in the body and pry to the rear of the vehicle. a snap will be felt/heard as the plastic stud releases
Move the prying tool to above 1 1/2 inch above the bottom of the assembly. Insert it between the assembly and body and gently pry toward the rear of the vehicle. This should free the second stud.
Now just pull the assembly straight back.
Locate the burned out bulb. In this case it was the indicator light. Rotate the bulb sockets in a counterclockwise direction.
Pull the sockets straight out of the tail light assembly.
다른 7명이 해당 안내서를 완성하였습니다.
