주요 콘텐츠로 건너뛰기
2008-2010 Audi A3 Sportback Hatch Lift Supports Replacement
필요한 것
  1. 2008-2010 Audi A3 Sportback Hatch Lift Supports Replacement, Hatch Lift Supports: 1 단계, 이미지 1/3 2008-2010 Audi A3 Sportback Hatch Lift Supports Replacement, Hatch Lift Supports: 1 단계, 이미지 2/3 2008-2010 Audi A3 Sportback Hatch Lift Supports Replacement, Hatch Lift Supports: 1 단계, 이미지 3/3
    • The lift supports of the rear hatch assist in the opening and closing of the hatch as well as hold the hatch open. They are thin, black suspension modules connecting the hatch to the main body on either side of the trunk opening.
    • The second photo shows an example of a busted strut due to rust. If your strut looks like so, replacing it is a good idea.
  2. 2008-2010 Audi A3 Sportback Hatch Lift Supports Replacement: 2 단계, 이미지 1/3 2008-2010 Audi A3 Sportback Hatch Lift Supports Replacement: 2 단계, 이미지 2/3 2008-2010 Audi A3 Sportback Hatch Lift Supports Replacement: 2 단계, 이미지 3/3
    • Before starting, be sure to disconnect any electrical connections. (see the introduction for full details and precautions)
    • Open the hatch and ask your helper to keep it open.
    • Start with the bottom connection of the strut. Slide the flat-head screwdriver into the slit and you should be able to easily slide it between the metal belt and the joint. Then remove the lower connection away from the ball joint.
    • Ensure that your partner is holding the hatch door securely up, as disconnecting the strut will increase the weight bearing down from the door.
  3. 2008-2010 Audi A3 Sportback Hatch Lift Supports Replacement: 3 단계, 이미지 1/3 2008-2010 Audi A3 Sportback Hatch Lift Supports Replacement: 3 단계, 이미지 2/3 2008-2010 Audi A3 Sportback Hatch Lift Supports Replacement: 3 단계, 이미지 3/3
    • These steps are the exact same for the bottom joint
    • Slide the flat-head screwdriver between the metal belt and the joint piece and gently push back the metal belt.
    • Once the belt is pulled back, pull the strut away from the ball joint connecting it to the car.
    • Pull the strut away from the lower ball joint and remove the strut, ensuring that your partner is holding the hatch door steady.
    • During reassembly, be sure to pry back the metal belts on each end of the strut before affixing them to the ball joints. The metal belts have a spring action, so you may need to pry them as you place them on to the ball joints, but be sure that the metal bar is pressed back into place so that the struts are firmly connected.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Paige Sandwell
회원 가입일: 10/30/19
263 평판
안내서 1개 작성함
University of Memphis, Team S4-G4, Kim Fall 2019 University of Memphis, Team S4-G4, Kim Fall 2019 회원
UM-KIM-F19S4G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 13
30일 전: 81
전체 시간: 3,223
