주요 콘텐츠로 건너뛰기
2008 Honda Pilot Tail Light Assembly Replacement
필요한 것
  1. 2008 Honda Pilot Tail Light Assembly Replacement, Tail Light Assembly: 1 단계, 이미지 1/2 2008 Honda Pilot Tail Light Assembly Replacement, Tail Light Assembly: 1 단계, 이미지 2/2
    • Open the vehicle's trunk to see the two bolts holding the assembly to the body.
    • Remove the two 8 mm bolts using either a Phillips head screwdriver or socket wrench.
    • Save the bolts! They will be needed for installing the new assembly.
  2. 2008 Honda Pilot Tail Light Assembly Replacement: 2 단계, 이미지 1/2 2008 Honda Pilot Tail Light Assembly Replacement: 2 단계, 이미지 2/2
    • Place both hands on the assembly and pull it away from the vehicle.
    • There are two clips on the back of the assembly that are connecting it to the vehicle. They will disengage if the assembly is pulled with adequate force.
    • If the clips won't disengage try using a rocking motion while pulling on the assembly.
  3. 2008 Honda Pilot Tail Light Assembly Replacement: 3 단계, 이미지 1/3 2008 Honda Pilot Tail Light Assembly Replacement: 3 단계, 이미지 2/3 2008 Honda Pilot Tail Light Assembly Replacement: 3 단계, 이미지 3/3
    • Unlock the three light sockets connected to the assembly by twisting them counter clockwise.
    • Pull the light sockets out of the assembly.
  4. 2008 Honda Pilot Tail Light Assembly Replacement: 4 단계, 이미지 1/3 2008 Honda Pilot Tail Light Assembly Replacement: 4 단계, 이미지 2/3 2008 Honda Pilot Tail Light Assembly Replacement: 4 단계, 이미지 3/3
    • Set the old assembly aside.
    • Take the new assembly, and put the light bulb sockets into their corresponding holes.
    • Twist each socket clockwise to lock them into place.
  5. 2008 Honda Pilot Tail Light Assembly Replacement: 5 단계, 이미지 1/3 2008 Honda Pilot Tail Light Assembly Replacement: 5 단계, 이미지 2/3 2008 Honda Pilot Tail Light Assembly Replacement: 5 단계, 이미지 3/3
    • Line the clips on the back of assembly up with their holes, and push the assembly into place.
    • Take the bolts from Step 2 and place them into the holes on the new assembly. Twist them clockwise until secure.
  6. 2008 Honda Pilot Tail Light Assembly Replacement: 6 단계, 이미지 1/1
    • Congratulations! You have installed a new tail light assembly on your vehicle!
결론
Congratulations! You have successfully completed the guide! Enjoy your new tail light assembly.
다른 한 분이 해당 안내서를 완성하였습니다.
John Forsyth
회원 가입일: 11/12/20
163 평판
안내서 1개 작성함
University of Memphis, Team S2-G20, Kim Fall 2020 University of Memphis, Team S2-G20, Kim Fall 2020 회원
UM-KIM-F20S2G20
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 469
