이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Open the vehicle's trunk to see the two bolts holding the assembly to the body.
Remove the two 8 mm bolts using either a Phillips head screwdriver or socket wrench.
Place both hands on the assembly and pull it away from the vehicle.
There are two clips on the back of the assembly that are connecting it to the vehicle. They will disengage if the assembly is pulled with adequate force.
Unlock the three light sockets connected to the assembly by twisting them counter clockwise.
Set the old assembly aside.
Take the new assembly, and put the light bulb sockets into their corresponding holes.
Twist each socket clockwise to lock them into place.
Line the clips on the back of assembly up with their holes, and push the assembly into place.
Take the bolts from Step 2 and place them into the holes on the new assembly. Twist them clockwise until secure.
Congratulations! You have installed a new tail light assembly on your vehicle!
다른 한 분이 해당 안내서를 완성하였습니다.
