주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2009 Mac Pro CPU Replacement (quad-core)
필요한 것
  1. 2009 Mac Pro CPU Replacement (quad-core), Remove the RAM: 1 단계, 이미지 3개 중 1개 2009 Mac Pro CPU Replacement (quad-core), Remove the RAM: 1 단계, 이미지 3개 중 2개 2009 Mac Pro CPU Replacement (quad-core), Remove the RAM: 1 단계, 이미지 3개 중 3개
    • While removing the RAM is not entirely necessary, it is a good idea so that you do not damage any of your chips while dealing with the heat sink.
    • Pop the tabs on the side and remove each chip individually.
    • Both the tabs and sticks may be stiff; be patient and use care.
  2. 2009 Mac Pro CPU Replacement (quad-core), Unscrew the heatsink: 2 단계, 이미지 1개 중 1개
    • Position your wrench in one of the screw holes and start to unscrew each bolt.
    • IMPORTANT: You must unscrew each screw an equal amount so you are removing the heatsink vertically and not at an angle. You could accidentally damage many of the components underneath the heatsink if you are not careful.
    • It may help to count off a number of turns as you're going to ensure that you apply even pressure in removing the heatsink.
    • I sharpied a line onto the one side of the handle of my hex key so I could more easily keep track of revolution count.
    • It took me about 17 turns on each screw to fully disconnect it, but your count may vary.
    • The screws are captive to the heatsink, so do not worry about removing them from the block.
    • You should hear a click as the screw pops out of the socket, as the screws are spring loaded.
    • On the 2009 models the CPU will come up with the heat sink, In this case skip step 5
  3. 2009 Mac Pro CPU Replacement (quad-core), Remove the heatsink from the tray: 3 단계, 이미지 3개 중 1개 2009 Mac Pro CPU Replacement (quad-core), Remove the heatsink from the tray: 3 단계, 이미지 3개 중 2개 2009 Mac Pro CPU Replacement (quad-core), Remove the heatsink from the tray: 3 단계, 이미지 3개 중 3개
    • Take care to pull the heatsink up straight off the tray, as there is a fan connector to the right of the CPU and you will need to take care not to bend it.
    • The connector is seen in blue in the first picture.
    • You will see the old thermal paste on both the CPU and the heatsink; we will remove the old paste before reassembling the tray.
    • This is also a great time to dust the tray if you have a can of compressed air. I was surprised just how much dust was present in my heatsink alone!
  4. 2009 Mac Pro CPU Replacement (quad-core), Clean the thermal paste from the heatsink: 4 단계, 이미지 1개 중 1개
    • Using a lint free cloth (such as a coffee filter) and high percentage isopropyl alcohol, clean the bottom of the heatpad on the heat sink. It should have a bright sheen to it once you have finished.
    • Take care not to bump the thermal sensor (shown in red)
    • You can also clean the paste from the old processor if you are planning on keeping it- just be very careful not to damage the underside of the CPU where the contacts are.
  5. 2009 Mac Pro CPU Replacement (quad-core), Replace the processor: 5 단계, 이미지 3개 중 1개 2009 Mac Pro CPU Replacement (quad-core), Replace the processor: 5 단계, 이미지 3개 중 2개 2009 Mac Pro CPU Replacement (quad-core), Replace the processor: 5 단계, 이미지 3개 중 3개
    • Carefully lift the arm on the side of the processor and lift it up to release the tray mechanism.
    • Remove the old processor carefully by the edges (I had on a pair of latex gloves just as an extra precaution)
    • Replace the new processor, taking care to line up the notches, which should go towards the hinge on the CPU cover. The pink arrows in the second image show the placement of the notches.
    • Carefully lower the cover and replace the arm. You will feel a bit of spring tension, but it should come down with relative ease.
  6. 2009 Mac Pro CPU Replacement (quad-core), Add thermal paste: 6 단계, 이미지 1개 중 1개
    • You'll need to re-apply thermal paste to the new processor. There are many schools of thought on the best way to do this, but I prefer to place a pea-sized dot in the middle of the CPU and let the heatsink spread it out for me.
  7. 2009 Mac Pro CPU Replacement (quad-core), Replace the heatsink: 7 단계, 이미지 1개 중 1개
    • Carefully replace the heatsink on top of the processor, taking care to ensure the fan connector is properly connected.
    • Begin to screw down the bolts again. You'll want to tighten in the same back and forth pattern to apply equal pressure across the processor.
    • DO NOT OVERTIGHTEN! It is very important to pay attention to the torque on the screws. Once a screw no longer wants to tighten with ease, back off.
  8. 2009 Mac Pro CPU Replacement (quad-core), Replace the RAM: 8 단계, 이미지 1개 중 1개
    • Replace the RAM and make sure to seat each stick firmly in its slot
  9. 2009 Mac Pro CPU Replacement (quad-core), Replace the tray & boot: 9 단계, 이미지 1개 중 1개
    • Replace the tray into your Mac Pro and fire it up! If you've done everything correctly, you should see your new processor listed in the About this Mac window.
    • If you experience high RPM fans, use a tool like iStat Menus to check the thermal temperatures and sensors. You may need to reset the PRAM or reseat the heatsink. I had no issues booting with mine, but your milage may vary.
결승점
다른 32명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Josh Calvetti
회원 가입일: 12/04/09
8,902 평판
안내서 2개를 작성함
18가이드 댓글
Mar 31, 2018
Maybe you can help. I did this upgrade on MacPro 4, 1-Did the firmware upgrade to 5,1. Complete the hardware install as listed above with 3.33 ghz processor. Started it up and only one of the Ram in working. Red LEDS on next to the back 3 ram slots. Switched around the Ram (although they are all the same for both the 4,1 & 5,1 models) to no avail. So I have only the #1 Ram slot working. Did the Pram reset a number of times. Did I screw up the board plane? Is that possible? I was extremely careful. Any thoughts on this would be appreciated.
Paolo Alberto - 답글
Does it still boot to macOS like normal, minus those three slots? Which CPU did you upgrade it to? I would ask in the Answers forum, as you’ll likely get more responses there.
Josh Calvetti -
I have mac pro 2009, Mac 4.1 but i install properties - system i see processes intel xeon E5520 2.27GHz. I want upgrade cpu and buy intel xeon x5680 update but not working after I upgrade firmware Mac become 5.1 “ i see in mac os”
let me know what CPU i can upgrade?
Tuan - 답글
I just put an X5690 (6x3.46GHz) in my single-processor 2009 Mac Pro after updating the firmware. It was super easy and everything seems to be working great. Just wanted to say thanks for this helpful guide!
tclash - 답글
Hi, I’m trying to do the same thing but after I put everything back up and turn it on, the mac chimes, then shows the apple logo and the loading bar, which only goes up halfway before restarting, in a loop. Did you have by chance similar symptoms?
Steve -
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 26
지난 30일: 208
전체 시간: 40,400
