주요 콘텐츠로 건너뛰기
2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement
필요한 것
  1. 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement, Key Fob Battery: 1 단계, 이미지 1/3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement, Key Fob Battery: 1 단계, 이미지 2/3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement, Key Fob Battery: 1 단계, 이미지 3/3
    • Here is the FOB for my Jeep. It decided to finally quit. The functionality became less over the last couple of weeks and required frequent attempts to unlock the vehicle etc.
    • Remove the key by moving
    • locking hatch to the left side first.
    • The two halves where the FOB needs to be split are clearly visible
  2. 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: 2 단계, 이미지 1/3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: 2 단계, 이미지 2/3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: 2 단계, 이미지 3/3
    • Using a plastic opening tool (or finger nail, guitar pick etc.) start at the front of the FOB to separate it
    • Moving the tool along the split line with slight sideways pressure
    • will separate the FOB easily.
  3. 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: 3 단계, 이미지 1/3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: 3 단계, 이미지 2/3 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: 3 단계, 이미지 3/3
    • Here is the cleanly opened FOB
    • Bottom half of the FOB contains the CR2032 coin battery
    • Remove the battery by pulling it out of the holder pushing it gently against the spring contacts.
    • Replace the battery following the polarity with the positive side to the body of the FOB
  4. 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: 4 단계, 이미지 1/2 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: 4 단계, 이미지 2/2
    • Insert wisdom here.
결론
다른 12명이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
782,480 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
33 회원들
안내서 544개 작성하였습니다
댓글 한 개
Very easy! Thank you!
Cheryl Talley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 17
7일 전: 103
30일 전: 484
전체 시간: 71,472
