주요 콘텐츠로 건너뛰기
3 - Toaster - Frequent problems
  1. 3 - Toaster - Frequent problems, What are the functions of the toaster?: 1 단계, 이미지 2개 중 1개 3 - Toaster - Frequent problems, What are the functions of the toaster?: 1 단계, 이미지 2개 중 2개
    • A toaster is a device or instrument used to hold slices of certain foods in front of a heat source for a specified period or not.
  2. 3 - Toaster - Frequent problems, Description: 2 단계, 이미지 1개 중 1개
    • Mark 1: Slots for inserting the slices of bread into the mobile basket. Usually in numbers of one or two up to 4.
    • Mark 2: Lever for lowering the baskets and switching on the toaster
    • Mark 3: Time delay setting button
    • Mark 4: Defrost button
    • Mark 5: Power on indicator
    • Mark 6: Quick stop and eject button
    • Mark 7: Crumb tray
    • The functions of the toaster presented are: - toast two slices of bread on both sides - adjust the cooking time using a graduated knob (timer adjustment) - interrupt cooking using a pusher ( button) - defrost slices of bread (push button) - collect the crumbs in a container
  3. 3 - Toaster - Frequent problems, General working principle: 3 단계, 이미지 3개 중 1개 3 - Toaster - Frequent problems, General working principle: 3 단계, 이미지 3개 중 2개 3 - Toaster - Frequent problems, General working principle: 3 단계, 이미지 3개 중 3개
    • When lever 1 moves down, it lowers the basket containing the bread as well as a cam labelled 2. When this cam arrives at the end of the rail, it gets in position in between the two copper plates of the bipolar switch labelled 3.
    • These two copper plates are used to power on the toaster.
    • If the toaster is plugged in, the lever is held down by an electro-magnet 4. Time setting of the magnet is chosen using the button placed on top of the toaster actuating the electronic timer 5
    • To toast bread, the device has a network of heating elements 6 placed on both sides of the basket on insulating plates 7. The elements are powered when the lever is held down.
  4. 3 - Toaster - Frequent problems, Electronic operating principle: 4 단계, 이미지 2개 중 1개 3 - Toaster - Frequent problems, Electronic operating principle: 4 단계, 이미지 2개 중 2개
    • When the lever is lowered, the contact pads of the bipolar switch 3 are closed. This allows the network of heating elements6, the electronic card 5 and the electromagnet 4 to be turned on.
    • When the electromagnet is powered, it keeps the lever lowered. This process is controlled by the timer on the electronic card.
    • When the time is up or the "stop" button is pressed, the timer releases the electro-magnet, which lets the lever rise with the tension of the spring and brings up the basket with the toasts inside. The toaster's circuit is then off.
  5. 3 - Toaster - Frequent problems, Electronic operating principle: 5 단계, 이미지 3개 중 1개 3 - Toaster - Frequent problems, Electronic operating principle: 5 단계, 이미지 3개 중 2개 3 - Toaster - Frequent problems, Electronic operating principle: 5 단계, 이미지 3개 중 3개
    • This is an example of an electronic diagram of a toaster timer. The manufacturers use various assemblies often based on a frequency oscillator and a timer (The MC14541BCP, datasheet provided here). The setting of the time is done with a potentiometer (P1 here).
    • Each device is slightly different, so we won't go into the detail of the electronics here.
    • The modified tip at the bottom of the diagram is worth noting. This prolongs the longevity of the contacts of the bipolar switch (see the chapter on the origin of toasters' breakdowns) Necessary tools: 1 triac BT138 + 1 resistance 4,7k
    • Source: http://www.rvq.fr/tech/g-pain.php
  6. 3 - Toaster - Frequent problems, Rupture of the heating element: 6 단계, 이미지 3개 중 1개 3 - Toaster - Frequent problems, Rupture of the heating element: 6 단계, 이미지 3개 중 2개 3 - Toaster - Frequent problems, Rupture of the heating element: 6 단계, 이미지 3개 중 3개
    • A common failure is a broken heating element. If the toaster does not heat up, or if the lever does not stay down (1), check the continuity of the resistance circuit with a multimeter.
    • To test the elements, connect the multimeter to the input terminal and then find the output terminal (in this case they are the white wires) and measure the resistance. It should be a resistance of less than 100 ohms (2).
    • If the element is broken, we need to find where the break is. We follow the length of the wire, which is wound around isolating plates made of mica. There are four in this toaster. The heating elements are connected in series at the back of the device by exposed wires. We can use these to make measurements.
    • On some toasters, the power supply of the electronic board is taken from the resistor circuit (in series).If the heating element is broken, then the electro-magnet which holds the lever down, wont stick.
    • Given that most toasters have a power rating of between 600 W and 1200 W, R =V²/P R=220²/600 = 80 ohms R=220²/1200=40 ohms
  7. 3 - Toaster - Frequent problems, Damaged heat resistor: 7 단계, 이미지 1개 중 1개
    • When the damage has been located, the repair can be carried out. The heat resistor is made with an alloy of nickel and chrome, and nichrome (*1) that's impossible to weld with ease. It is therefore necessary to create a connection either with a piece of wire as a strap, or with a crimping sleeve (*2)
    • Warning: The disassembly to access the insulating plates is a delicate process. We must focus on solutions that allow repair without having to disassemble. See video (*2)
    • (*1) Nichrome wire coils are available on the internet for the repair of electronic cigarettes
    • (*2) watch the video https://youtu.be/YXq3go-NgYE from 10 minutes)
  8. 3 - Toaster - Frequent problems, Bipolar switch: 8 단계, 이미지 1개 중 1개
    • Since the power of the device is between 600 and 1200W, the bipolar switch (marker 2) must support a current between 2.5 and 5A (1), which is important given its small size. When contacts deteriorate, their resistance will increase and the heat will dissipate in the switch and eventually burn them.
    • If the contacts have been fried, the repair will involve cleaning them with a small fine file by squeezing the file between the contacts with a clamp if necessary. Make sure that the cam (1) closes the two contacts well by pushing downright on the slats.
    • An improvement can be made by adding a triac to replace the inter responsible for energy switching; the switch will then only function as a control. This modification can be viewed on the electronic diagram in the "how it works" section.
    • (1) Knowing that the power of toasters is generally between 600 and 1200w, P=U*I > I=1200/220 = 5,5A > I=600/220=2,7A
결론
There you are! After having studied the previous two guides on toasters, the functionalities, and the different sub-assemblies that compose it, we have reviewed the main causes for toaster breakdowns.
We hope this empowers you to know more about your device and have the capacity to repair it yourself.
If you enjoyed this guide (or not!), don't hesitate to leave us feedback. And if you are in our area (Atelier Soudé, come visit us. We organize workshops for co-repair, popularization sessions, and more...
다른 16명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Atelier Soudé
회원 가입일: 12/13/18
4,642 평판
안내서 18개를 작성함
14가이드 댓글
Il faut que j’aille sur ifixit pour trouver un tuto de l’atelier soudé…. Les Lyonnais sont donc partout ?!? Merci pour l’explication. Je vais tenter de trouver du fil Ni-Cr pour réparer ce grille-pain trouvé dans le local poubelle de mon immeuble. Si je galère je passerai à une permanence à Lyon.
AlexFixeurs - 답글
yes merci ! grace à vous j’ai réussi à trouver la rupture de la résistance et à la réparer ! bon j’ai mis un peu de temps à comprendre comment y accéder par contre… mais avec la vidéo top! j’ai fait 2 petits trous dans la plaque et j’ai relié les 2 bouts de “fils” coupés avec la partie métallique d’une gaine à sertir et mon grille pain remarche!!! longue vie à mes tartines grillées du matin !
Héloïse DANO - 답글
Merci! Dans mon cas, c'était des salissures sur la partie supérieure de l'électro-aimant. Après nettoyage, ça remarche. Sans vous, je jetais mon grille-pain.
Philippe V - 답글
Ou trouver les clés spéciales pour démonter les pieds merci
josselyne.becede - 답글
Bonjour, pour ma part j'ai pas trouvé de clé spéciale du coup j'ai percé les vis spéciales et j'ai mis des vis à bois à la place ;-)
Rémi Bourjas -
댓글 쓰기
조회 통계:
지난 24시간: 25
지난 7일: 231
지난 30일: 933
전체 시간: 58,665
