주요 콘텐츠로 건너뛰기
3DR Iris Plus Quadcopter Propeller Replacement
필요한 것
  1. 3DR Iris Plus Quadcopter Propeller Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Power off the drone by holding down the power button.
    • Remove the battery by disconnecting it from the main battery connector.
    • Press the power button again to ensure all electricity is discharged.
    • This step is imperative as it is dangerous to handle drone components with a running current!
  2. 3DR Iris Plus Quadcopter Propeller Replacement, Propeller: 2 단계, 이미지 2개 중 1개 3DR Iris Plus Quadcopter Propeller Replacement, Propeller: 2 단계, 이미지 2개 중 2개
    • Take note of the propeller cap color (either black or silver).
    • Hold down the motor assembly and twist the propeller clockwise to unlock it (you should feel some resistance until it starts to unscrew freely).
    • Hold down the motor assembly and twist the propeller counterclockwise to unlock it (you should feel some resistance until it starts to unscrew freely).
    • This is the motor assembly.
  3. 3DR Iris Plus Quadcopter Propeller Replacement: 3 단계, 이미지 2개 중 1개 3DR Iris Plus Quadcopter Propeller Replacement: 3 단계, 이미지 2개 중 2개
    • Ensure that the propeller cap color (black or silver) matches the propeller screw cap color.
    • There are two different types of propellers so make sure you're using the correct one.
결론
To reassemble your device, follow these directions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Wanjiku Gichigi
회원 가입일: 02/10/20
196 평판
안내서 1개를 작성함
Cal Poly, Team S7-G5, Regan Winter 2020 Cal Poly, Team S7-G5, Regan Winter 2020 회원
CPSU-REGAN-W20S7G5
5 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 488
