주요 콘텐츠로 건너뛰기
4Sight 9 Battery Replacement
필요한 것
  1. 4Sight 9 Battery Replacement, Cover: 1 단계, 이미지 1/2 4Sight 9 Battery Replacement, Cover: 1 단계, 이미지 2/2
    • Place the tablet on its side so that the two screws are facing upward.
    • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
  2. 4Sight 9 Battery Replacement: 2 단계, 이미지 1/1
    • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
    • Once loosened, use your hands to separate the case from the device.
  3. 4Sight 9 Battery Replacement: 3 단계, 이미지 1/2 4Sight 9 Battery Replacement: 3 단계, 이미지 2/2
    • Hold the positive and negative wires as close as possible to the speaker.
    • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
  4. 4Sight 9 Battery Replacement, Battery: 4 단계, 이미지 1/1
    • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
    • For a complete guide on how to solder, click here.
  5. 4Sight 9 Battery Replacement: 5 단계, 이미지 1/2 4Sight 9 Battery Replacement: 5 단계, 이미지 2/2
    • Insert plastic prying tool under upper-hand corner of battery and slide back and forth.
    • Once loosened, insert plastic prying tool under lower-hand corner and repeat sliding action.
    • Repeat previous actions until battery comes loose from device.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Jack Applegate
회원 가입일: 04/07/15
413 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 1,690
