주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
8BitDo Pro 2 D-Pad Replacement
필요한 것
  1. 8BitDo Pro 2 D-Pad Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Flip the 8BitDo Pro 2 controller so that the back side is facing up.
    댓글 쓰기
  2. 8BitDo Pro 2 D-Pad Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery cover off to remove it and expose the battery.
    댓글 쓰기
  3. 8BitDo Pro 2 D-Pad Replacement: 3 단계, 이미지 1개 중 1개
    • Use your hands to remove the battery pack from the controller.
    • Do not bend or puncture the battery pack, this can be hazardous.
    댓글 쓰기
  4. 8BitDo Pro 2 D-Pad Replacement, Controller: 4 단계, 이미지 1개 중 1개
    • Using the iFixit blunt tweezers, peel back the top two corners of the sticker located inside the battery compartment.
    댓글 쓰기
  5. 8BitDo Pro 2 D-Pad Replacement: 5 단계, 이미지 1개 중 1개
    • Use a T6 Torx screwdriver to remove the four 5.0 mm screws from the back of the controller.
    댓글 쓰기
  6. 8BitDo Pro 2 D-Pad Replacement: 6 단계, 이미지 3개 중 1개 8BitDo Pro 2 D-Pad Replacement: 6 단계, 이미지 3개 중 2개 8BitDo Pro 2 D-Pad Replacement: 6 단계, 이미지 3개 중 3개
    • Insert the iFixit pick into the seam along the edge of the controller and slide it around to release the clips holding it together.
    • Leave opening picks in the space to keep the top and bottom case from reattaching.
    • Use an iFixit tool to carefully pry around the edges of the controller.
    • Once loosened, gently separate the top and bottom of the controller.
    • Do not separate the top and bottom sections, as they are still connected by a ribbon cable.
    댓글 쓰기
  7. 8BitDo Pro 2 D-Pad Replacement: 7 단계, 이미지 2개 중 1개 8BitDo Pro 2 D-Pad Replacement: 7 단계, 이미지 2개 중 2개
    • Use a spudger to gently push up on alternating sides of the black plastic tab until it clicks up into its unlocked position.
    • Don't push the tab too hard or too far, otherwise it may come completely off the connector.
    • Use tweezers to gently pull the cable out of its socket.
    • The cable should be able to slide in and out of the socket with little to no force. If you feel resistance, the tab may not be fully unlocked.
    • During reassembly, insert the cable into its socket and use the flat end of a spudger to push the tab down into its locked position.
    • Separate the top and bottom casing of the controller.
    • If you feel resistance, check for any cables still connecting the two halves and avoid forcing them apart.
    댓글 쓰기
  8. 8BitDo Pro 2 D-Pad Replacement, D-Pad: 8 단계, 이미지 3개 중 1개 8BitDo Pro 2 D-Pad Replacement, D-Pad: 8 단계, 이미지 3개 중 2개 8BitDo Pro 2 D-Pad Replacement, D-Pad: 8 단계, 이미지 3개 중 3개
    • Remove the six, 10.0 mm Phillips #00 screws along the edge of the main board.
    • Remove the 5.0 mm Phillips #00 screw towards the center of the board.
    • Pull the main board from the top case to remove it.
    댓글 쓰기
  9. 8BitDo Pro 2 D-Pad Replacement: 9 단계, 이미지 1개 중 1개
    • Gently pull the conductive rubber cover off the D-pad.
    댓글 쓰기
  10. 8BitDo Pro 2 D-Pad Replacement: 10 단계, 이미지 1개 중 1개
    • Push the D-Pad out of the top case to remove it.
    • You may heard a clicking sound as the D-Pad is removed.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Paige Lucas
회원 가입일: 03/03/26
563 평판
안내서 5개를 작성함
UMass Dartmouth, Team 5-3, Rioux Spring 2026 UMass Dartmouth, Team 5-3, Rioux Spring 2026 회원
UMASSD-RIOUX-S26S5G3
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 26
지난 30일: 34
전체 시간: 63
