주요 콘텐츠로 건너뛰기
ACER Aspire V5-571P-6609 Battery Replacement
필요한 것
  1. ACER Aspire V5-571P-6609 Battery Replacement, Battery Replacement: 1 단계, 이미지 1개 중 1개
    • Place the laptop facing down and find the slider close to the battery.
    • Use a screwdriver or other pointed tool to slide it to the right.
  2. ACER Aspire V5-571P-6609 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • While keeping the slider pushed to the right, use your other hand to pull the battery out from the right side to the left until it completely comes out.
  3. ACER Aspire V5-571P-6609 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Install the new battery with the little tabs facing the laptop. Although keeping the slider pushed to the right when installing the new battery is recommended, it is not necessary; the battery can be inserted until it clicks in place.
결론
No Reassembly Required
작성자
3다른 기여자 명과 함께
Mauricio O.
회원 가입일: 08/25/22
97 평판
안내서 1개를 작성함
Gateway, Team 1-1, Pee Fall 2022 Gateway, Team 1-1, Pee Fall 2022 회원
GCC-PEE-F22S1G1
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 24
전체 시간: 287
