주요 콘텐츠로 건너뛰기
AEE Mach 1 Motherboard Replacement
필요한 것
  1. AEE Mach 1 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Take out the AEE Mach 1 and place it on a flat surface with its propellers facing up.
  2. AEE Mach 1 Motherboard Replacement: 2 단계, 이미지 1/2 AEE Mach 1 Motherboard Replacement: 2 단계, 이미지 2/2
    • Holding the base of each propeller still, unscrew the propeller clockwise for each arm.
  3. AEE Mach 1 Motherboard Replacement: 3 단계, 이미지 1/1
    • Flip the drone so that the bottom of the AEE Mach 1 is facing up.
  4. AEE Mach 1 Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the five screws on the drone's arms using a Torx T5 screwdriver.
  5. AEE Mach 1 Motherboard Replacement: 5 단계, 이미지 1/1
    • Gently pry open the top panel of the drone using a spudger.
    • Do not completely remove the panel, as there will still be wired connections between the two halves.
  6. AEE Mach 1 Motherboard Replacement: 6 단계, 이미지 1/1
    • Take out and set aside the battery pack, located on the back of the AEE Mach 1.
  7. AEE Mach 1 Motherboard Replacement: 7 단계, 이미지 1/1
    • Rotate the top panel slightly to reveal the four screws beneath each propellor arm.
    • Remove each of the four screws with a Phillips #0 screwdriver.
    • Lift off the top panel, as it should now be free from the rest of the device.
  8. AEE Mach 1 Motherboard Replacement: 8 단계, 이미지 1/2 AEE Mach 1 Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove the four screws from each corner of the motherboard with a Phillips #00 screwdriver.
  9. AEE Mach 1 Motherboard Replacement: 9 단계, 이미지 1/2 AEE Mach 1 Motherboard Replacement: 9 단계, 이미지 2/2
    • Use a plastic spudger to gently remove the copper tape from the mother board.
  10. AEE Mach 1 Motherboard Replacement: 10 단계, 이미지 1/1
    • Peeling up the copper tape will expose another metal chip that has wires that are soldered to the mother board.
    • Remove the four screws holding the secondary board in place using a Phillips #00 screwdriver.
  11. AEE Mach 1 Motherboard Replacement: 11 단계, 이미지 1/3 AEE Mach 1 Motherboard Replacement: 11 단계, 이미지 2/3 AEE Mach 1 Motherboard Replacement: 11 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the ZIF connector joining the motherboard and secondary board by prying up the locking black tab and pulling out the cable with some blunt nosed tweezers.
    • Desolder the red and black wires joining the two boards.
    • For help soldering, check out our How To Solder and Desolder Connections guide.
  12. AEE Mach 1 Motherboard Replacement: 12 단계, 이미지 1/1
    • Remove the motherboard by lifting it from the case.
결론
Jake Kenison
회원 가입일: 09/16/20
205 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 25
전체 시간: 246
