주요 콘텐츠로 건너뛰기
AKASO KingPad A90 WiFi Antenna Replacement
필요한 것
  1. AKASO KingPad A90 WiFi Antenna Replacement, WiFi Antenna: 1 단계, 이미지 1/3 AKASO KingPad A90 WiFi Antenna Replacement, WiFi Antenna: 1 단계, 이미지 2/3 AKASO KingPad A90 WiFi Antenna Replacement, WiFi Antenna: 1 단계, 이미지 3/3
    • Remove screws.
    • Insert spudger tool on the middle of the left side, between the white and black plastic.
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed.
    • Pull off the back cover.
  2. AKASO KingPad A90 WiFi Antenna Replacement: 2 단계, 이미지 1/3 AKASO KingPad A90 WiFi Antenna Replacement: 2 단계, 이미지 2/3 AKASO KingPad A90 WiFi Antenna Replacement: 2 단계, 이미지 3/3
    • Plug in soldering iron and let it warm up for ten minutes.
    • Locate the the soldering points of the antenna on the motherboard.
    • Peel back the protective tape that covers the display ribbon cable so it isn't too close to the soldering points.
    • Solder hardens and cools quickly; you don’t need to wait to move on to the next step.
  3. AKASO KingPad A90 WiFi Antenna Replacement: 3 단계, 이미지 1/3 AKASO KingPad A90 WiFi Antenna Replacement: 3 단계, 이미지 2/3 AKASO KingPad A90 WiFi Antenna Replacement: 3 단계, 이미지 3/3
    • If you do not know how to solder, be careful and follow steps precisely because you could otherwise ruin the device.
    • With the new antenna locate the solder points.
    • Add solder to the solder points to allow soldering.
    • Place the antenna at each point and melt the solder point.
    • Place the antenna solder location into the melted solder blob and let it sit for about 2 seconds.
    • Repeat this step for each of the solder points.
  4. AKASO KingPad A90 WiFi Antenna Replacement: 4 단계, 이미지 1/3 AKASO KingPad A90 WiFi Antenna Replacement: 4 단계, 이미지 2/3 AKASO KingPad A90 WiFi Antenna Replacement: 4 단계, 이미지 3/3
    • Replace the back cover with the new part in place.
    • Gently press the speaker into place.
    • Don't let the volume rocker unit fall out of place.
    • Replace the screws.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Daniel Garcia
회원 가입일: 03/24/15
179 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 회원
UMASSD-VIJAYBHASKAR-S15S4G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 630
