주요 콘텐츠로 건너뛰기
APEX TM785CH Microphone Replacement
필요한 것
  1. APEX TM785CH Microphone Replacement, Back Casing: 1 단계, 이미지 1/2 APEX TM785CH Microphone Replacement, Back Casing: 1 단계, 이미지 2/2
    • Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
    • Wedge a plastic opening tool into the opening and push it down to force the back cover off.
    • Move along the top edge of the tablet and repeat the step above.
    • Pull the back cover away from the tablet body to completely remove it.
  2. APEX TM785CH Microphone Replacement, Microphone: 2 단계, 이미지 1/3 APEX TM785CH Microphone Replacement, Microphone: 2 단계, 이미지 2/3 APEX TM785CH Microphone Replacement, Microphone: 2 단계, 이미지 3/3
    • The microphone is located in the bottom center of the tablet.
    • Remove the black tape holding the wires down.
    • Remove the black tape holding the microphone in place.
    • The microphone is now exposed and can be gently pulled out of the socket.
  3. APEX TM785CH Microphone Replacement: 3 단계, 이미지 1/1
    • You will need a soldering/desoldering kit to desolder the 2 leads where the microphone connects to the circuit board.
결론
Brian Graschel
회원 가입일: 03/23/15
823 평판
안내서 6개 작성하였습니다
Baylor, Team 4-1, Williams Spring 2015 Baylor, Team 4-1, Williams Spring 2015 회원
BU-WILLIAMS-S15S4G1
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 9
전체 시간: 176
