주요 콘텐츠로 건너뛰기
ASUS F550 Keyboard Replacement
필요한 것
  1. ASUS F550 Keyboard Replacement, ASUS F550 HDD/Ram Cover Removal: 1 단계, 이미지 1/2 ASUS F550 Keyboard Replacement, ASUS F550 HDD/Ram Cover Removal: 1 단계, 이미지 2/2
    • Remove the battery, using release clips.
    • Ensure device has no residual power by attempting boot once battery is removed.
    • Remove either 2 (or 4 for a full teardown) 12mm phillips screws, then removing the bottom cover to gain access to the HDD and RAM.
    • Remove HDD and RAM cover
  2. ASUS F550 Keyboard Replacement, Keyboard: 2 단계, 이미지 1/1
    • Remove 7 5mm Phillips screws
  3. ASUS F550 Keyboard Replacement: 3 단계, 이미지 1/3 ASUS F550 Keyboard Replacement: 3 단계, 이미지 2/3 ASUS F550 Keyboard Replacement: 3 단계, 이미지 3/3
    • Flip laptop and open lid. Separate the keyboard plate from the main housing, using a plastic prying tool. Being careful not to damage the LED indicators or other peripheries.
    • Disconnect the LED, trackpad, and keyboard ribbon cables.
    • The keyboard can now be removed
결론
다른 8명이 해당 안내서를 완성하였습니다.
Ryan
회원 가입일: 08/19/15
1,414 평판
안내서 14개 작성하였습니다
댓글 3개
great help in getting to the keyboard. keyboard removal requires breaking all the securing posts , but quite easy.
just make sure there are no little bits left on assembly. also take your time and gently fold back all earth straps and insulators etc and then fold back after keyboard is fitted. didn't have one but maybe a hot glue gun would be useful to just pin a few things down.??
anyway all works well so thankyou.
dave - 답글
with a good prying tool shouldn't break any components, i use steel guitar picks and standard plastic wedge tools to separate the parts, however glad to know this guide helped.
Ryan -
Thanks for the instructions posted above. Very helpful.
New question. Can the basic keyboard itself be replaced without recourse to replacing the surrounding frame. I attach a link to illustrate what I want to do. The link shows the basic keyboard on it’s own without the fruit ans salad around it. Thanks
https://www.ebay.com.au/itm/362389048708
christonic1 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 22
전체 시간: 9,314
