주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS F550 RAM Replacement
필요한 것
  1. ASUS F550 RAM Replacement, ASUS F550 HDD/Ram Cover Removal: 1 단계, 이미지 2개 중 1개 ASUS F550 RAM Replacement, ASUS F550 HDD/Ram Cover Removal: 1 단계, 이미지 2개 중 2개
    • Remove the battery, using release clips.
    • Ensure device has no residual power by attempting boot once battery is removed.
    • Remove either 2 (or 4 for a full teardown) 12mm phillips screws, then removing the bottom cover to gain access to the HDD and RAM.
    • Remove HDD and RAM cover
  2. ASUS F550 RAM Replacement, Remove Ram: 2 단계, 이미지 2개 중 1개 ASUS F550 RAM Replacement, Remove Ram: 2 단계, 이미지 2개 중 2개
    • Release securing arms and remove RAM.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ryan
회원 가입일: 08/19/15
1,519 평판
안내서 14개를 작성함
3가이드 댓글
Pretty sure only 2 of the 4 screws need to be removed.
tobiaskuhn - 답글 공유
Can confirm only two screws required removal to enable access on my model F550C
Have successfully replaced HD once, but had slight issue getting it recognised
which is more of a BIOS issue, helps if you have a seperate bootable USB drive
but once recognised and OS installed, have several times swapped between the two
HDs (one Win8, one Linux - eventually plan to only use linux on this system).
Regards
Mike.
mihaly_k - 답글 공유
Yes only two need to be removed, however I initially wrote a tear down to gain access to the network card etc and the way ifix it is structured for guide creation these steps are in fact used in that longer guide. I've amended the instructions now so hopefully they are more clear now.
Ryan - 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 41
전체 시간: 5,019
