주요 콘텐츠로 건너뛰기
ASUS G73JH-BST7 SD Hard Drive Replacement
필요한 것
  1. ASUS G73JH-BST7 SD Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 ASUS G73JH-BST7 SD Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the computer over, so that the bottom is facing up.
  2. ASUS G73JH-BST7 SD Hard Drive Replacement: 2 단계, 이미지 1/3 ASUS G73JH-BST7 SD Hard Drive Replacement: 2 단계, 이미지 2/3 ASUS G73JH-BST7 SD Hard Drive Replacement: 2 단계, 이미지 3/3
    • Slide the two tabs away from the battery.
    • The left tab will lock, but the right tab must be held away from the battery.
  3. ASUS G73JH-BST7 SD Hard Drive Replacement: 3 단계, 이미지 1/3 ASUS G73JH-BST7 SD Hard Drive Replacement: 3 단계, 이미지 2/3 ASUS G73JH-BST7 SD Hard Drive Replacement: 3 단계, 이미지 3/3
    • Use one hand to hold the non-locking tab in place, and use your other hand to pull the battery away from the computer.
  4. ASUS G73JH-BST7 SD Hard Drive Replacement, Back Panel: 4 단계, 이미지 1/3 ASUS G73JH-BST7 SD Hard Drive Replacement, Back Panel: 4 단계, 이미지 2/3 ASUS G73JH-BST7 SD Hard Drive Replacement, Back Panel: 4 단계, 이미지 3/3
    • With the bottom of the computer facing up, remove the two 7.1 mm screws using a Phillips #00 screwdriver.
  5. ASUS G73JH-BST7 SD Hard Drive Replacement: 5 단계, 이미지 1/3 ASUS G73JH-BST7 SD Hard Drive Replacement: 5 단계, 이미지 2/3 ASUS G73JH-BST7 SD Hard Drive Replacement: 5 단계, 이미지 3/3
    • Carefully pry the panel away from the computer, by lifting with a finger.
    • There is a small tab where a finger will fit to lift the panel away from the computer.
  6. ASUS G73JH-BST7 SD Hard Drive Replacement, SD Hard Drive: 6 단계, 이미지 1/3 ASUS G73JH-BST7 SD Hard Drive Replacement, SD Hard Drive: 6 단계, 이미지 2/3 ASUS G73JH-BST7 SD Hard Drive Replacement, SD Hard Drive: 6 단계, 이미지 3/3
    • Gently pull on the tabs to lift the SD Hard Drives out of the computer.
결론
Deven Rodgers
회원 가입일: 10/23/18
253 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 396
